The Ultimate Router Base Template Guide Accessory Kit
- An indispensable accessory for The Ultimate Router base
- Produce perfectly matched curved joinery and dead-centred inlays every time
- 1-1/2" (38.1mm) and 2" (50.8mm) removable bushings that offset a 1/2" router bit to either side of the cutting seam
- Centring pin for precise mounting alignment
- Parallel drawing disk to assist in cutting layouts
- Assembly tools included
An indispensable accessory for The Ultimate Router base, The Ultimate Router Base Template Guide Set allows you to produce perfectly matched curved joinery and dead-centred inlays every time.
The set includes 1-1/2" (38.1mm) and 2" (50.8mm) removable bushings that offset a 1/2" router bit to either side of the cutting seam. A centring pin for precise mounting alignment and a parallel drawing disk to assist in cutting layouts. Plus, all the assembly tools.
The Ultimate Router Base System is exclusive to Axminster Tools in the UK and when you add The Ultimate Router Base Template Guide it will turn your handheld router into the most versatile tool in your workshop.
EAN Barcode | 712038186174 |
