UJK Air Wedge - Wide 260mm
- Inflatable shims with dozens of uses
- For fitting, fixing or levelling; slimline, slides into a 2mm gap
- Hand operated for controlled inflation
- Hard-wearing, non-marring material
- Sealed and glued with TPU and high frequency welding
- Wide: size 260mm x 140mm, lift 2mm to 85mm
UJK Air Wedge - Square 160mmSpecial Price ÂŁ10.58 ÂŁ8.82 was ÂŁ17.58 ÂŁ14.65 Save ÂŁ7.00 ÂŁ5.83
UJK Air Wedge - Slim 100mmSpecial Price ÂŁ10.38 ÂŁ8.65 was ÂŁ15.98 ÂŁ13.32 Save ÂŁ5.60 ÂŁ4.67
UJK Wedges (Pkt 2)Special Price ÂŁ4.63 ÂŁ3.86 was ÂŁ6.18 ÂŁ5.15 Save ÂŁ1.55 ÂŁ1.29
Axminster Professional Forged Flat Bar Clamp 200 x 80mmSpecial Price ÂŁ11.68 ÂŁ9.73 was ÂŁ15.58 ÂŁ12.98 Save ÂŁ3.90 ÂŁ3.25
WoodSpur Torx Head Wood Screw Assortment (1,500 Pieces)Special Price ÂŁ24.98 ÂŁ20.82 was ÂŁ29.98 ÂŁ24.98 Save ÂŁ5.00 ÂŁ4.17
UJK Level BoxSpecial Price ÂŁ19.98 ÂŁ16.65 was ÂŁ24.98 ÂŁ20.82 Save ÂŁ5.00 ÂŁ4.17
Axminster Professional Stainless Steel Metric Rule - 300mmSpecial Price ÂŁ2.68 ÂŁ2.23 was ÂŁ3.58 ÂŁ2.98 Save ÂŁ0.90 ÂŁ0.75
The UJK Air Wedge uses the same principle that air-jacks use to lift large commercial vehicles weighing many tons.
Versatile doesn’t even begin to describe the UJK Air Wedge. Whether you are fitting, fixing or levelling, the UJK Air Wedge makes the job a great deal easier. The UJK Air Wedge is good for lifting something up, pushing something into position or forcing things apart. Made from highly durable, non-marring material and with triple welded seams, the UJK Air Wedge is virtually indestructible. An internal stiffener makes it easy to insert the UJK Air Wedge into a narrow gap. By gently squeezing the bulb, you can make controlled, fine adjustments. Press the release valve to deflate the Air Wedge.
Initially marketed as a tool for holding window frames in place prior to fixing, it is indispensable in many other situations. When fitting a door, a UJK Air Wedge underneath one corner makes it easy to align the hinges. For levelling kitchen appliances or cabinets, use a UJK Air Wedge to lift a fridge or washing machine etc while you make adjustments.
Wide: size 260mm x 145mm, lift 2mm to 85mm, maximum lifting weight 180kg.
EAN Barcode | 5052511101740 |
