UJK Air Wedges - Square 160mm (Pkt 2)
720608
From ÂŁ31.98 ÂŁ26.65
41 Reviews
In Stock - Ready to dispatch
  • Inflatable shims with dozens of uses
  • For fitting, fixing or levelling; slimline, slides into a 2mm gap
  • Hand operated for controlled inflation
  • Hard-wearing, non-marring material
  • Sealed and glued with TPU and high frequency welding
  • Square: size 160mm x 145mm, lift 2mm to 55mm
It's all very well having one Air Wedge, but what's going to hold up the other side? Perhaps a pack of two may help.
Versatile doesn’t even begin to describe the UJK Air Wedge. Whether you are fitting, fixing or levelling, the UJK Air Wedge makes the job a great deal easier. The UJK Air Wedge is good for lifting something up, pushing something into position or forcing things apart. Made from highly durable, non-marring material and with triple welded seams, the UJK Air Wedge is virtually indestructible. An internal stiffener makes it easy to insert the UJK Air Wedge into a narrow gap. By gently squeezing the bulb, you can make controlled, fine adjustments. Press the release valve to deflate the Air Wedge.
Initially marketed as a tool for holding window frames in place prior to fixing, it is indispensable in many other situations. When fitting a door, a UJK Air Wedge underneath one corner makes it easy to align the hinges. For levelling kitchen appliances or cabinets, use a UJK Air Wedge to lift a fridge or washing machine etc while you make adjustments.
Square: size 160mm x 145mm, lift 2mm to 55mm, maximum lifting weight 180kg.
4.10 41
