UJK Router Table with Laminated Top
- UJK Professional Laminated Router Table Top
- Low friction phenolic laminate surface
- Aluminium extrusion track for mitre fences and accessories
- Thick birch ply core; will not warp over working life
- Accepts any UJK table insert
- Dust collection box available
- UJK Professional Router Table Fence
- Adjustable infeed and outfeed fences
- T-slot for accessories at the top and front of the fence
- Graduated scale provided along top of fence
- Transparent dust extraction port with 63mm outlet
- UJK Professional Router Table Leg Stand
- Sturdy steel components with good mobility
- Foot operated retractable castor for mobility around the workshop
- Stand height approximately 890mm
- Rack provided for your most popular router cutters
- Storage for mitre fence assembly
- Show More
Package deal comprises the UJK Professional Laminated Router Table Top, UJK Professional Router Table Fence and UJK Professional Router Table Leg Stand
The UJK Professional Laminated Router Table Top is high-grade birch ply with a hard wearing, low friction, phenolic laminated surface. The ply core ensures the top will remain flat throughout its working life, while the laminated top ensures workpieces glide smoothly. An extruded aluminium track inset into the table top includes a standard 19mm track for the use of a mitre fence and a T-track slot for other jigs and accessories. The 230 x 306mm central aperture will accept any of the UJK router table inserts as well as the UJK router elevator. The top measures 800 x 600mm.
The UJK Professional Fence consists of a single extruded aluminium section supplied with a transparent 63mm dust port for efficient extraction from above the table. T-slots at both the top and front of the fence allow for the fitting of other accessories or guards. An adjustable transparent guard is included for your safety. The infeed and outfeed fences attach to either side of the aluminium section. The central aperture is variable to accommodate cutters of different diameters. The fence assembly includes scales for attachment at either side of the table and along the top of the fence. The fence measures 904 x 90mm high.
The UJK Professional Router Table Leg Stand is of sturdy construction with a foot operated retractable castor for excellent mobility around the workshop. A neat rack on one side keeps your most popular router cutters to hand and there is provision for storage of a mitre fence assembly. Stand height approximately 890mm.
