Faithfull Plastic Pipe Cutter Pro Capacity 3-42mm
109706
From £17.78 £14.82
  1. Empty Star
  2. Empty Star
  3. Empty Star
  4. Empty Star
Write a review
Low Stock - Ready to dispatch
Delivery Premium
Next Day Delivery from £8*.
Order within for delivery by Tuesday 15th Jul
  • Cut plastic pipes up to 43mm O/D
  • Heavy-duty ratchet requires less effort
  • Progressive cutting action and clean burr free finish
  • Super sharp stainless steel blade
  • Pipe is held securely as the pressure increases
  • Heavy-gauge cast aluminium body
  1. Faithfull Plastic Pipe Cutter Pro Capacity 3-42mm
Total:
£98.56 £82.13
The Faithfull Professional Plastic Pipe Cutter features a ratchet mechanism, which makes cutting almost effortless. This pipe cutter is capable of cutting plastic pipes up to 43mm O/D. It’s made from heavy-gauge cast aluminium with a heavy-duty ratcheting mechanism. The ratchet mechanism maintains pressure so that the handles only need to be opened and closed a few times to complete a cut.
The stainless steel blade has a lopper style profile for a smooth, progressive cutting action and a clean burr free finish. The blade works against the lower anvil jaw, ensuring the pipe is held securely as the pressure increases.
Capacity: 3-42mm.
