Festool TCT Saw Blades Thin Kerf - 160mm x 1.8mm x 20mm
From £37.48 £31.23
2 Reviews
  • 1.8mm thin kerf saw blades for maximum performance
  • Cut faster and achieve a perfect result
  • Fits Festool TS 55 F, TSC 55 K and HK 55, HKC 55 saws
These high tech, high spec blades ensure the job gets done faster and with a better result - a new generation of thin kerf saw blades, designed to give maximum performance. The 1.8mm thin kerf saw blades and tooth geometry allows you to work faster, reduces the load on the machine and, in the case of cordless tools, extends battery runtimes.
The blade teeth are high-quality carbide resulting in a long service life. There are blades for different applications, each with the tooth format required to achieve a perfect cut.
These blades fit the Festool TS 55 F and TSC 55 K plunge-cut saws, as well as the HK 55 and HKC 55 portable circular saws
Please note these do not fit Festool TS55R or other previous models, as these take 2.2mm kerf blades.
5.00 2
