Festool DOMINO DF 700 Expansion Bolt SV-SA D14
102360
102360
From £37.38 £31.15
  1. Empty Star
  2. Empty Star
  3. Empty Star
  4. Empty Star
Write a review
Low Stock - Ready to dispatch
Delivery Premium
Next Day Delivery from £8*.
Order within for delivery by Tuesday 3rd Jun
  • SV-SA D14 split anchor used to form a corner of frame connection
  • Requires the SV-AB D14 anchor bolt and SV-QA D14 cross anchor
  • Other parts purchased separately
  • Suitable for material thicknesses of 30mm or more
  • Uses the DOMINO XL DF 700 to produce the joint
  • Supplied in boxes of 32
  1. Festool DOMINO DF 700 Expansion Bolt SV-SA D14
Total:
£171.52 £142.93
The SV-SA D14 split anchor, is one element of a corner of frame connection. It requires the SV-AB anchor bolt and the SV-QA D14 cross anchor to form the complete corner or frame joint. Other parts can be purchased separately.
The DOMINO connector revolution makes fast, accurate and powerful connections with the option of quick and easy disassembly and reassembly. The connector system for the DOMINO XL DF 700 joining machine is suitable for material thicknesses of 30mm or more.
Using the DOMINO XL DF 700 to produce the joint is an extremely quick process using only the machine’s stops or simple pencil markings. It requires no other accessories or templates. The finished joint is extremely stable. Cover caps are available in three colours for a high-quality corner connection appearance. Supplied in boxes of 32.
