Service Update
You can still order online for home delivery and contact our team of experts for advice. Please note, it is currently taking 5-7 days for orders to be delivered.. You can't visit our stores, they're temporarily closed. Learn more.
Festool Planex Easy LHS-E 225 EQ Long Reach Sander
  • For sanding walls and ceilings, plasterboard, drywall filler, etc.
  • Comes ready assembled and set up in handy carrying bag
  • Low weight and even weight distribution for tireless handling
  • Robust and powerful EC motor with variable speed
  • 1.6m length and flexible joint gives excellent reach and movement
  • Ultra-soft sanding pad adapts perfectly to wall and ceiling surfaces
  • Removable brush segment for sanding close to an edge
  • Always use an appropriate mobile dust extractor
  • Show More
£688.96 (£574.13 Ex. VAT)
Click & Collect is temporarily unavailable. As of 24th March our retail outlets are all temporarily closed. Our website and warehouses remain open and are despatching as normal. For more information please click here.
We're commited to selling high-quality products, however we also know that there are times when you need to exchange or return an item.
Find out more
Description
In Detail
Festool 3 Year Warranty (Registration Required)
The PLANEX Easy LHS-E 225 EQ sands walls and ceilings, plasterboard and dry wall filler, coats of paint, loose plaster and other coatings. This exceptionally well-designed, long-reach sander performs perfectly. The PLANEX Easy LHS-E 225 EQ comes ready assembled and set up. Take it out of its carrying bag and get started without delay. The relatively low weight (only 4kg) and even weight distribution allows you to work longer without getting tired. The robust and powerful brushless EC motor drives the sanding head directly, doing away with the need for any additional gearing. Fitted with variable speed selection, constant electronics maintain the speed under load.
The 1.6m length gives you plenty of reach, while its flexible joint provides a great deal of room for movement. The ultra-soft sanding pad adapts perfectly to wall and ceiling surfaces ensuring maximum surface quality. When sanding close to an edge, a removable brush segment means you can get right into the angle between two walls or wall and ceiling.
Always use an appropriate mobile dust extractor.
Specification
Specification
Corded or Cordless Corded
Dust Extraction 36 mm Outlet
Model LHS-E 225 EQ
Motor Power 400 W
Nett Weight 4 kg
Pad Size 215 mm
Rating Industrial
Sound Power Level [Uncertainty K] 80 dB(A) [3.0 dB]
Sound Pressure Level [Uncertainty K] 69 dB(A) [3.0 dB]
Vibration Sanding [Uncertainty K] 2.5 m/s² [1.5 m/s²]
No Load Speed 400 - 920 rpm
We think you'll like
Reviews
Customer Reviews
Questions
Questions and Answers
Privacy Policy & Cookies
