Festool ROTEX RO 150 FEQ-Plus Sander
Spread the cost of orders up to £30,000 with iwocaPay.
We accept iwocaPay to give business customers more control when it comes to paying. iwocaPay is available for UK Limited Businesses, LLPs and Sole Traders on orders of £150 to £30,000.
When you get to the iwocaPay checkout you'll see two choices:
- Pay Now in just a few clicks, you can scan a code to pay us straight from your bank account.
- Pay Later you'll be able to set up a payment plan with iwocaPay to split the cost with Pay in 3 (Interest Free) or Pay in 12 (3.33% Interest Rate Per 30 Days) equal monthly payments.
- Extended abrasive life with 'MULTI-JETSTREAM 2 pad', reduces heat and prevents clogging
- Eccentric motion for high quality, scratch-free surfaces
- Perfect grip position for every working situation
- Pad made from MPE high tear resistant durable material
- Minimal vibration
- FastFix tool free sanding pad system, Plug It Hose
- Sanding up to the edge, bottom of handle can be removed
- 3 Year warranty on registration (excluding base) available
Festool Accessory Polishing Pad (PT-STF D150 MJ-FX)From £29.88 £24.90
This RO150FEQ Rotex sander from Festool is more powerful, economical and ergonomic and few other sanders offer such control and high finish. Rotex was the very first geared eccentric sander and set ground-breaking standards with its innovative 3-in-1 principle. Coarse sanding, fine sanding or polishing, it does the work of three tools. The powerful motor and long life gear unit gives high performance under load, fitted with an MPE 'MULTI-JETSTREAM 2' sanding backing pad.
The MULTI-JETSTREAM 2 pad works using intake air and exhaust air to generate airflow transporting the sanding dust away from the pads surface so that the abrasive wears evenly without clogging as well as keeping the surface at a low temperature. The result is almost 100% dust extraction for an improved rate of material removal, a better finish and a healthy working environment. Made from MPE high tear resistant material the pad is also very durable.
Supplied with MPE sanding base (soft), edge protector and Systainer® T-LOC SYS3 storage case.
Benefits
- Includes 36 month machine guarantee
- Full repair, free of charge
- Replaced in the event of theft
- Original parts guaranteed
- 14 day money back
EAN Barcode | 4014549149034 |
Corded or Cordless | Corded |
Dust Extraction | 27 mm Outlet |
Manufacturer Part Number | 571808 & 571809 |
Motor Power | 720 W |
Nett Weight | 2.3 kg |
No Load Speed | Rotary 320 - 660 rpm, Orbital 3,300 - 6,800 opm |
Orbit Diameter | 5.0 mm |
Pad Size | 150 mm |
Rating | Trade/Professional |
Sound Power Level LwA [Uncertainty K] | 93 dB(A) [3.0 dB] |
Sound Pressure Level LpA [Uncertainty K] | 82 dB(A) [3.0 dB] |
Vibration Sanding [Uncertainty K] | 4.0 m/s² [1.5 m/s²] |
Voltage | 230 V |
