Festool Screwdriver & CENTROTC Drill Set 18
109878
From £73.28 £61.07
  1. Empty Star
  2. Empty Star
  3. Empty Star
  4. Empty Star
Write a review
Dispatching Soon
- Email me when available
Delivery
Free Standard Delivery*.
Dispatch estimate is within 2 weeks.
  • Mix of 12 screwdriver bits and 6 precise CENTROTEC drill bits
  • The mixed short screwdriver bits cover Pozi, Phillips and Torx
  • Drill bits for wood, solid and manmade as well as MDF and acrylic
  • Brad point drills with centre point and clean cutting spurs
  • Drills supplied 3mm, 4mm, 2x5mm, 6mm and 8mm
  • Bits; PZ1, PZ2 and PZ3, PH1, PH2 and PH3, TX10, TX15, TX20, TX25, TX30 and TX40
A very handy set of 12 screwdriver bits covering Pozi, Phillips and Torx drive and 6 short precise brad point drill bits with CENTROTEC fitting. The drill bits have a brad point design, sharp centre point and outer cutting spurs, these HSS will give great results with repeat performance as they are made from high alloyed ball bearing steel. The short durable screwdriver bits have hex shanks.
Suitable for all Festool drills including the CXS ,TXS 12V and 18V drills. Simply insert it into the CENTROTEC tool chuck and lock it, and you're ready for efficient working. The CENTROTEC fitting allows for simple and quick bit change in the Festool CENTROTEC chuck that also locks the bit in place and can be easily ejected even with gloves on for speed and efficiency.
Supplied in a strong case that will also fit into a Festool compartment case lid.
Drill bits: 3mm, 4mm, 2 x 5mm, 6mm and 8mm diameters.
Screwdriver bits; PZ1, PZ2 and PZ3, PH1, PH2 and PH3, TX10, TX15, TX20, TX25, TX30 and TX40.
