The DS400 is supplied with an easy-to-use single valve controlled RF80 torch which allows one-hand operation. Supplied with a solid refractory hearth with robust side and rear heat shields, the DS400 complies with British Gas standards and is a fully failsafe system. All sequences are visually displayed using neon indicators. On start-up the gas train, hoses and torches are tested for escaping gas. Leaks from any component will result in a continuously illuminated red neon and the main flow of gas will be prevented from entering the system.
This product is classified as an Enquiry product. Enquiry
products require contact with our friendly team prior to
purchase to understand your requirements. Typically these products have many
customisation options or require product training.
Enquiry products are usually readily available and often despatched directly
from the manufacturer using the best delivery service available. Despatch
times can vary between manufacturers and delays may occur should stock become
unavailable. Please contact customer services for more information.
