The LN1000 gas fired kiln is perfect for both students and professionals. The kiln can be put to a variety of uses including metal heat treatment, enamelling, melting precious metals and wax burnouts. The kiln can reach 850°C in 10 minutes with an optimum temperature of 1,000°C in 35 minutes. The constant heat input combined with super efficient insulation produces a stable operating temperature with minimum gas usage. Due to its low weight the kiln can be portable as well as permanently installed.
Simple to install and maintain and designed for use with natural gas or low pressure bottled gas. Electrical requirement 13A, 230V.
This product is classified as an Enquiry product. Enquiry
products require contact with our friendly Business Services team prior to
purchase to understand your requirements. Typically these products have many
customisation options or require product training.
Enquiry products are usually readily available and often despatched directly
from the manufacturer using the best delivery service available. Despatch
times can vary between manufacturers and delays may occur should stock become
unavailable. Please contact customer services for more information.
