From £999.98 £833.32
In Stock
  • Max depth of cut 200mm, max width of cut 340mm
  • Extra large cast iron table, precision ground surface
  • Smooth running, vibration-free balanced cast alloy blade wheels
Customers Also Bought
High specification, modest price
The AP2552B bandsaw is a very popular sized machine for the trade or home workshop.
Welded Steel Body
The robust body of the bandsaw makes the machine rigid for more stability and an accurate cut.
Extra Large Cast Iron Table
With a precision ground surface, the table offers excellent support and a smooth cutting surface.
Deep Section Rip Fence
Supported front and back, the fence provides full support when ripping thicker pieces of timber.
Micro Adjustable Blade Guides
The ball bearing blade guides make the bandsaw easier to set up and also help to achieve more accuracy when cutting.
Twin Trunnion Table Support
This provides excellent support and aids towards a vibration free cut.
Quick Blade Detensioning
This handy feature helps to extend the life of the blade, and save wear on the tyres.
Guide Height Control
For quick, simple and accurate set up, the guide height is both rack and pinion controlled.
Added Safety Features
There’s an adjustable T-slotted precision mitre fence as well as interlocked and micro-switched doors and an emergency stop switch to safeguard you while you work.
Choose a selection of Axcaliber blades
Our super sharp blades are made in Britain - from start to finish. You'll benefit from quiet and smooth cuts, plus a long service life.
Shop 2,552 mm bladesRead our buying guide
Buy with confidence
So sure are we of the quality of this saw, we cover all parts and labour free of charge for three years! Find out more
The AP2552B bandsaw, with its high specification is a very popular sized machine for the professional or dedicated amateur.
The combination of a rigidly built steel body, large and finely ground cast iron table, deep section rip fence and micro adjustable ball bearing blade guides produces the high level of performance demanded by full time craftspeople. The rip fence runs on a calibrated aluminium extrusion and locks firmly in place with a lever, giving a solid and accurate location. The adjustable precision mitre fence is T-slotted into the table for added safety and accuracy. The table tilt quadrants are set very widely apart to give the maximum support to the table and to make the tilt action very smooth. Cutting depth is controlled by a well engineered rack and pinion system, with a lock to set the guides into position.
At the rear of the machine are the blade tracking control, the blade tension indicator and a quick action blade tension lever, useful for both blade changing and for releasing the tension on the blade when the machine is not in use. The powerful induction motor transmits its power via a multi-groove flat belt, ensuring smooth running and zero slip. Safety features include interlocked and micro-switched doors and an emergency stop switch.
Beautifully made and sure to please. Supplied with floor stand, rip fence, mitre fence and a 6tpi bandsaw blad.
Machine Classification
    4.80 75
