Axminster Woodturning Evolution SK114 Chuck
From £259.98 £216.65
  • Manufactured entirely in Axminster, UK
  • Square key for positive location and extra torque
  • Stainless steel body for maximum corrosion resistance
  • Direct threaded chuck body ensures concentricity
  • CNC manufacturing for superb accuracy
  • Supplied with soft grip chuck key
  • Fitted with SafetyJaw© accessory mounting jaws
  • 114mm (4.5") diameter
  • Lifetime guarantee
Woodturning continues to evolve
Our chuck system is just the start of a new generation of true British Made, quality engineered products that have evolved and been carefully manufactured with pride in Axminster. The system is devised to maximise work holding on the lathe, it is cleverly thought out and proven by our own turners and customers who, over the years, have offered ideas or constructive criticism. Read more...
Buy with confidence
The Axminster Lifetime Guarantee is available on Axminster Woodturning Evolution SK100 and SK114 Chucks, provided the chuck has been properly maintained. Find out more
Made in Axminster
The first all British-made super precision woodturning chuck system packed with innovation and accuracy...
Stainless steel & worthy of super precision status
We are mindful that chucks can corrode so stainless steel is the perfect choice of material for the chuck. Other chucks are plated which requires the chuck to be made undersized and accept the plating process to bring it into tolerance. The Evolution SK114 is not plated but is machined to tolerance for a perfect fit of both jaws and lathe mandrel.
By machining the scroll register and cutting the thread all in one operation, we can ensure that no errors arise in concentricity. In fact there is no perceivable error in this process. Our jaws are machined to within 2 microns, giving us accuracy worthy of super precision status.
C dovetail jaws
One of our most versatile and popular jaw sets, these are especially useful for small bowls and end grain work such as boxes and goblets as well as bowl turning.
Faceplate ring
No need for a separate faceplate. Simply screw the ring to the chosen blank with woodscrews and expand the dovetail jaws into the recess in the centre of the ring.
Screw chuck
Particularly useful for the initial mounting of bowl blanks whilst the outer form and the dovetail base are being shaped.
Soft grip chuck key
Three hardened pinions ensure the chuck is always accessible, from any angle, to tighten with the key. The key has special grips to avoid slippage and has a warm tactile feel. It is always good practice to tighten all three pinions when securing a large piece of work on the lathe.
Finely machined SafetyJaw
Manufactured in our own machine shop in Axminster, these long accessory mounting jaws are unrivalled for quality and precision. We like to call them SafetyJaws because a unique feature of these jaws is that if extended beyond the body of the chuck, the edges have been modified with a slight radius to minimise the chance of injury should hands get too close to the rotating chuck during use. Added safety features also help to ensure the jaws correctly mounted safely to the chuck.
Smoother, faster and cleaner
The standard chuck is 50mm deep and is designed to sit as close to the headstock bearings as the mandrel will allow. This minimises vibration and gives a much smoother turn allowing for faster and cleaner cuts, extremely important when turning large hollow forms. It is also good engineering practice and does not overload or test the bearings in any way.
Reverse locking is available on the M33 x 3.5mm chuck. It is achieved with unique yet simple facial locking screws which can be dedicated to the lathe to ensure that the lathe spindle register is not damaged in any way.
Axminster Woodturning Lifetime Guarantee
The Axminster Woodturning Lifetime Guarantee is available on Axminster Woodturning Evolution SK100 and SK114 Chucks. We're so confident in the manufactured quality of our chucks that, in the unlikely event a fault should occur, we cover all parts and labour free of charge for life!
Together with Axminster's 3 Year Guarantee on Machinery, it's probably the most comprehensive free guarantee ever - buy with confidence from Axminster! So sure are we of the quality, we cover all parts and labour free of charge for five years!
History
Back in 1984 we produced our very first woodturner's chuck having thought long and hard about what would be an ideal chuck for a woodturning lathe. As engineers, we automatically preferred a scroll chuck and as three jaws were totally out of the question for woodturners (cutting triangular stock is just not that easy), the four jaw chuck system was born.
It wasn't long before we explored all manner of different accessories for the chuck as engineering style jaws were a little limited if not dangerous. We devised a style of mounting four quadrants of a profiled disc that we called jaws, these jaws are still to this day compatible with all the chucks we have made. It is important to us to ensure that the accessories you purchased yesterday will still work with the chucks we make and sell today.
Something we never anticipated was that our chucks would be copied so much and that the market would be so large. Our design was based around interchangeable sets of jaws where the accessory jaws were interchangeable from set to set, whereas other makers relied upon just the one set of jaws, changing eight screws every time you change the profiled quadrants.
Advice from our experts
Read our Buying Guides or contact us to find out more
Which chuck is right for me?
The range of Axminster woodturning chucks now covers almost every type of work-holding requirement. Read the guide and compare our chucks to help you decide.
Can I use my existing Axminster jaws?
The Evolution slide-ways and scroll are compatible with any jaws that have been made for Axminster chucks. Our resident turners are here to help you understand the system.
Watch our videos
More than thirty-five years ago, Axminster produced and marketed one of the world’s first four jaw self centring chucks for woodturners. Over the years, much of the development has come from the feedback and input of professional woodturners. With over three decades of experience in production and design, we believe these latest chucks are the very best on the market today. Manufacturing of the Evolution chucks, jaws and accessories is done entirely in our production facility here in Axminster.
The Evolution SK114 features a super-slim 114mm (4.5") diameter stainless steel body incorporating our SafetyJaw© accessory mounting jaws. The ultra-compact design keeps the workpiece as close as possible to the headstock of your lathe to lessen the load on the bearings and prevent unwanted vibration during heavy stock removal. The longer accessory mounting jaws increase the contact area within the slide ways of the chuck, further minimising vibration during use. The Evolution is fully compatible with all accessory jaws and is the first of a new series of chucks and jaws. All you need to do is choose the chuck thread to suit your lathe.
Made entirely in Axminster, England.
Note: 108808 - M33x3.5mm (with Euro ASR groove) Chuck is only suitable for use on lathes with an M33x3.5 EURO standard (ASR) spindle and requires the 109370 ASR Locking Ring in order for the chuck to be run in reverse.
Warranty Axminster Woodturning Chuck Lifetime Guarantee
The Axminster Woodturning Chuck Lifetime Guarantee is available on Axminster Woodturning Evolution SK100 and SK114 Chucks. We're so confident in the manufactured quality of our chucks that, in the unlikely event a fault should occur, we cover all parts and labour free of charge for life!
It's probably the most comprehensive free guarantee ever - buy with confidence from Axminster.
Find out more
British Made British Made
Customer AccountThe outline of a personCustomer BasketA shopping basket with a handleBritish MadeBritish Made logoBulk BuysA star with lots of pointsBusiness ServicesA building with a door at the frontCatalogueAxminster Tools CatalogueCategoriesView categoriesClick & CollectA shopping bag with a handleClockA clock face showing the timeThe CommunityAxminster Tools & Machinery Forum LogoCompareCompare productsDeliveryA van delivering parcelsPremium DeliveryA van delivering parcels fastCopyCopy to the clipboardEditEdit itemEmailAn envelopeEventbriteThe logo for the Eventbrite websiteExpandTwo arrows pulling away from each otherFacebookThe logo for FacebookFilterDots in a triangle shape pointing downfinanceA walletInstagramThe logo for InstagramiwocaPayiwocaPay payment logoLinkedInThe logo for LinkedInLocationA location markerMade in BritainMade in Britain logoMenuThree Horizontal lines stacked on top of each otherNotificationA notification bellPartnerBuy from our PartnersPay By FinanceNovuna Finance LogoPayPalPayPal payment service logoPayPal CreditPayPal credit payment service logoPhoneAn old style telephone receiverPinterestThe logo for PinterestPoint RightAn arrow in a circle pointing rightPrinterA printer, printing a piece of paperPrivatePadlockRemoveTwo lines in a x shapeReturnAn arrow in a circle pointing back to the startRewardsAxminster Tools RewardsSettingsView SettingsSortOne arrow pointing up, one arrow pointing downSpinA circle that spins to show that the page is loadingStockA circle which is coloured to show the current stock levelTagA clothing label tagTeachableThe Logo for TeachableTickA tick symbolTrade AccountSaving tag iconDeleteDeleteUnavailableA no entry signVideo PlayA Circle with a video play symbol insideWarrantyA screwdriver and a spanner in an x shapeWhatsAppThe logo for WhatsAppWishlistA heart symbolWood OutlineWood effectYouTubeThe logo for YouTube
4.90 107
