From £449.98 £374.98
In Stock
  • Depth of cut: 135mm with 260mm width of cut
  • Rigid, welded body construction allows high blade tension for increased accuracy
  • Integrated dual port dust extraction, just one connection port
Customers Also Bought
A great addition to any home workshop, large or small
The Axminster Workshop AW1950B Bandsaw is a premium, compact bandsaw with many new features not normally found on machines of this size.
Buy with confidence
So sure are we of the quality of this saw, we cover all parts and labour free of charge for three years! Find out more
Smooth running
A steel body and balanced aluminium wheels ensures the machine runs very smoothly.
Excellent dust extraction
With dual extraction ports, you can rest assured you’re safeguarding not only your health, but keeping your workshop clean at the same time.
Upper and lower bearing blade guide supports
The ball bearing blade guides make the bandsaw easier to set up and also help to achieve more accuracy when cutting.
Twin trunnion table support
This provides excellent support and aids towards a vibration free cut.
Solid fence
A cam locking fence allows for accurate cuts. For convenience, it can be used either side of the blade.
Optional mitre fence
A standard 19mm mitre fence slot provides the option for many optional accessories to be used.
How to get the best out of your AW1950B
Learn how to set it up for accurate cuts
Our experts show you everything you need to know, right through to making your first cut!
Choose a selection of Axcaliber blades
Our super sharp blades are made in Britain - from start to finish. You'll benefit from quiet and smooth cuts, plus a long service life.
Shop 1,950 mm bladesRead our buying guide
The AW1950B is a compact bandsaw with many features not normally found on machines of this size.
It gives you a 135mm maximum depth of cut. It has a strong welded and braced steel frame along with a generously sized cast iron table with a steel plate rear extension. The widely spaced mounting trunnions underneath the table give extra table support and ensure that the table tilt is a smooth operation. A standard 19mm mitre fence slot is provided. The rip fence cam-locks solidly to the front rail and is adjustable to the blade for accuracy. Twin scales allow the fence to be used on either side of the blade.
The bandsaw has ball bearing side and thrust guides; these give great support and are very easy to set up. Once set, they stay set unless you change the width of the blade. A rack and pinion system adjusts the upper blade guide height.
The dust extraction is via two ports, one close to the bottom guides, the other in the lower wheel cabinet. An interconnecting hose means just one 63mm connection port needs coupling to a suitable vacuum extractor. There are twin blade speeds, giving flexibility for many jobs. A powerful induction motor with a multi V belt drives the bandsaw and is quiet and reliable.
Supplied with a steel leg stand with rubber feet and a UK made blade (10mm x 6 TPI Skip Tooth). This could be the perfect bandsaw for most "shed-in-the-garden-garage-workshops".
Warranty Axminster Workshop 3 Year Guarantee
Machine Classification
These products are designed and intended to be used in the Home Workshop for light work and not continuous use. They must be maintained and serviced in line with our schedule. Guarantee may be void when used for business or educational purposes.
    4.60 212
