Bosch 43 Piece Screwdriver Bit & Holder Set
- Comprehensive bit and holder set in strong case
- Contains Pozi, Phillips, Slotted, Hex
- Torx, tamper proof Torx and Nut drivers
- Quick change holder and standard bit holder
- 50mm long series bits also in set
- Colour coded for ease of selection
This professional bit set contains screwdriver tips: Pozi, Phillips, Hex and Torx, nut drivers and a choice of two bit holders all supplied in a tough storage case.
This 43 piece set contains screwdriver bits: Pozi PZ1, 2 and 3, Phillips Ph1, 2 and 3, Slotted 3, 4, 5 and 6mm, Torx T10,15, 20, 25, 27, 30 and T40, Th (tamper proof Torx) Th10,15, 20, 25, 27, 30 and 40, Hex 3, 4, 5, 6 and 50mm long series PZ2, PH2, Slotted 5mm, T15, 20 and 25, nut drivers 6, 8 and 10mm. Standard bit holder and quick change bit holder.
EAN Barcode | 3165140669702 |
