Bosch Impact Control Empty Bit Case
107242
107242
- Tough ABS, empty Pick and Clic bit storage case
- Build a personal bit set to suit individual requirements
- Case features fixing slots for pick and Clic plastic holders
Show more
Show less
Build your own personalised bit set with this Bosch Pick and Click box. This empty box has slots ready to receive the plastic bit holders of bits sets available in the rest of the Pick and Click range. The empty box gives you control over the choice of bits to suit your own requirements.
There is space for bits on both the top and bottom. The box is a tough ABS moulding with rubber corner bumpers for extra protection. It has a metal hinge pin for strength and a sliding latch to keep it locked securely. Size: 150 x 110 x 25mm.
EAN Barcode | 3165140851534 |
Overall L x W x H | 150 mm x 110 mm x 25 mm |
