Bosch T101D Jigsaw Blades Fast Wood Cutting
AX23413
AX23413
- 60mm thick hard and soft wood, plywood and chipboard
- Fast cutting
- Available in packs of 5 or 25
Show more
Show less
Hard and soft wood, plywood and chipboard up to 60mm thick, fast cutting.
Blade Type | HCS, Ground and Taper Ground |
Jigsaw Blade Length | 74 mm |
Jigsaw Blade Type | Fast Cutting |
Max Cutting Depth | 60 mm |
Tooth Pitch \ tpi | 4.23 mm \ 6 tpi |
#AxminsterTools
