Crown Mini Spiralling Tool
952463
952463
- Creates some interesting effects on your turned work
- Simple to sharpen with a diamond file
- Create spirals and other textured patterns
Surface decoration on turned work can certainly enhance the piece and when used in conjunction with colour and/or liming wax, some striking effects can be accomplished. This tool will produce spirals on your spindle work and the width of spiral can be changed by changing the angle of presentation to the work. To set this angle for consistent repeatable results, an indexing sleeve is attached to the main shaft of the tool with two hex head bolts. Two spiralling wheels are provided to further vary the effect, one wheel having 17 teeth and the other 27. Full instructions are supplied with the tool.
