DeWALT DWS780 305mm Mitre Saw
- Large cutting capacity, up to 345mm width
- XPS shadow line cut indicator for accurate alignment with the cut line
- Grooving stop for trenching or rebating
- Cam action mitre lock function for angles 50°L and 60°R
- Quick release setting of bevel angles up to 49° L and R
- Dual sliding fence gives plenty of support for tall workpieces
Axcaliber Contract TCT Saw Blade Neg Rake - 305mm x 3.2mm x 30mm 72TFrom £46.18 £38.48
The 305mm diameter blade gives you outstanding cutting performance. The DWS780 offers effortless accuracy from cutting small profiles to large section timbers up to 110 x 303mm. This is a heavy-duty machine, built for durability and fully adjustable to maintain accuracy over the life of the tool. Easy-to-use mitre and bevel controls make the tool fast and simple to change from one set-up to another. A quick release bevel stop helps set accurate bevel angles up to 49° left and right. A cam action mitre lock function makes mitre setting fast and easy for angles between 0° - 50° left and 0° - 60° right. The grooving stop allows you to cut grooves or rebates. The XPS shadow line cut indicator gives you a unique and accurate way to align the blade, at the same time illuminating the work. The large dual sliding fence gives plenty of support for tall workpieces at any angle. The electronic speed control lets you adjust cutting speed when cutting materials other than wood. Supplied with 60 tooth TCT blade, blade spanner, dust bag and material clamp.
The product must be registered by the original DEWALT Product user within 4 Weeks of Purchase by visiting the DEWALT website (DEWALT Product user contact details, tool catalogue number, serial number and date code required). Kits comprising a range of tools are excluded from registration, but individual tools from kits must be registered.
For full terms and conditions click here.
In order to make a claim, you will need to submit proof of purchase to us or an authorised DEWALT repair agent, and the product must display the CE mark.
*Some products are excluded from the 3 year guarantee. A detailed summary of individual product guarantees is available on the DEWALT website.
Bevel Angle Range | 49° - 0 - 49° |
Blade Diameter | 305 mm |
Blade RPM | 1,900 - 3,800 rpm |
Bore Size | 30 mm |
Dust Collection | Dust Bag Supplied |
EAN Barcode | 5035048332320 |
Max Bevel Cut @ 45º W x H | 345 mm x 44 mm or 268 mm x 63 mm |
Max Compound Cut @ 45º W x H | 212 mm x 76 mm |
Max Crosscut @ 0º W x H | 345 mm x 76 mm or 303 mm x 110 mm |
Max Mitre Cut @ 45º W x H | 244 mm x 76 mm or 211 mm x 112 mm |
Mitre Angle Range | 50° - 0 - 60° |
Model | DWS780 |
Motor Power | 1,675 W |
Nett Weight | 24.8 kg |
Overall L x W x H | 770 mm x 470 mm x 396 mm |
Rating | Trade/Professional |
Sound Power Level LwA [Uncertainty K] | 100 dB(A) [3.0 dB] |
Sound Pressure Level LpA [Uncertainty K] | 88 dB(A) [3.0 dB] |
Voltage | 230 V |
