Festool ROTEX RO 125 FEQ-Plus Sander
- Compact, extremely manoeuvrable, lightweight and very versatile
- ROTEX allows the machine to be either an aggressive or fine sander/polisher
- Flick the switch and choose between a rotary/eccentric or an eccentric action
- Tool-less FastFix sanding pad change system simplifies pad changing and saves time
- MULTI-JETSTREAM airflow pad for even abrasive wear, preventing clogging
- Pad made from MPE high tear resistant durable material
- Brake and smooth-running pad
- For left and right handers
- Softgrip ensures a safe, comfortable grip
- Dust proof gear casing and floating switches ensure trouble-free work
- Supplied with MPE soft sanding pad, edge protector and Systainer T-LOC case SYS2.
- Show More
Three tools in one with high class surface results, perfect for coarse sanding, fine sanding and polishing on vertical or narrow surfaces, above head height and around tight curves. It is compact, extremely manoeuvrable, lightweight and very versatile.
ROTEX allows the machine to be either an aggressive or fine sander as well as a polisher. Just flick the switch and you can choose between a rotary / eccentric action for coarse sanding and polishing that will keep the surface temperature low or an eccentric action only for fine sanding.
MMC electronics for constant speed
FASTFIX pad change system, pad brake
125mm JETSTREAM pad for effective extraction/abrasive life and finish
MPE high tear resistant material ensures the pad is very durable
Dust proof gear casing and floating switches also ensure trouble-free work.
Supplied with soft sanding pad, edge protector and Systainer 2 T-LOC case SYS2
Benefits
- Includes 36 month machine guarantee
- Full repair, free of charge
- Replaced in the event of theft
- Original parts guaranteed
- 14 day money back
Corded or Cordless | Corded |
Dust Extraction | 27 mm Outlet |
EAN Barcode | 4014549148761 |
Manufacturer Part Number | 571784 |
Model | RO125FEQ-PLUS |
Motor Power | 500 W |
Nett Weight | 1.9 kg |
No Load Speed | Rotary 300 - 600 rpm, Orbital 3,000 - 6,000 opm |
Orbit Diameter | 3.6 mm |
Pad Size | 125 mm |
Plug Fitted | UK 3 pin plug |
Rating | Trade/Professional |
Sound Power Level LwA [Uncertainty K] | 92 dB(A) [3.0 dB] |
Sound Pressure Level LpA [Uncertainty K] | 81 dB(A) [3.0 dB] |
Vibration Sanding [Uncertainty K] | 7.5 m/s² [1.5 m/s²] |
Voltage | 230 V |
