Festool TCT Saw Blade Aluminium/Plastic - 216mm x 2.3mm x 30mm 64T
- 64 teeth, 216mm diameter, 30mm bore
- Designed for cutting aluminium panels and profiles
- Suitable for Perspex, hard and fibre-reinforced plastics
- Cuts non-ferrous metals and aluminium composite panels
The Festool TCT (Tungsten Carbide Tipped) circular saw blades offer a perfect combination of cutting performance and quality results. Manufactured in accordance with Festool’s uncompromising standards, they have generous carbide tips ensuring a long working life. These 216mm blades fit the Festool KS60 compound sliding mitre saw, but can of course fit any saw able to take this size. The TF64 features 64 teeth designed for cutting aluminium panels and profiles, Perspex, hard and fibre-reinforced plastics, non-ferrous metals and aluminium composite panels.
Blade Diameter | 216 mm |
Bore Size | 30 mm |
EAN Barcode | 4014549212219 |
Hook Angle | 0° |
Kerf | 2.3 mm |
Maximum RPM | 5,000 rpm |
Model | TF64 |
Plate Thickness | 1.6 mm |
Teeth | 64 |
Tooth Format | TCG |
