Festool TCT Saw Blade Fine - 216mm x 2.3mm x 30mm 60T
103649
103649
- 60 teeth, 216mm diameter, 30mm bore
- For clean, splinter-free crosscuts
- Designed for cutting solid wood and coated or veneered panels
- Generous carbide tips ensuring a long working life
Show more
Show less
The Festool TCT (Tungsten Carbide Tipped) circular saw blades offer a perfect combination of cutting performance and quality results. Manufactured in accordance with Festool’s uncompromising standards, they have generous carbide tips ensuring a long working life. These 216mm blades fit the Festool KS60 compound sliding mitre saw, but can of course fit any saw able to take this size. The W60 features 60 teeth, designed for clean, splinter-free crosscuts in solid wood as well as coated or veneered panels.
Blade Diameter | 216 mm |
Bore Size | 30 mm |
EAN Barcode | 4014549212240 |
Hook Angle | 5° Negative Rake |
Kerf | 2.3 mm |
Maximum RPM | 5,000 rpm |
Model | W60 |
Plate Thickness | 1.6 mm |
Teeth | 60 |
Tooth Format | ATB |
