JSP SpringFit™ Fold Flat Valved Respirator FFP3 Carbon Layer (Pkt 10)
106087
106087
From £30.98 £25.82
  5. Half Star
2 Reviews
  • Buy 10 for £27.89 £23.24 each
Low Stock - Ready to dispatch
  • Fold flat disposable masks, high protection level FFP3
  • Activated carbon layer removes nuisance odours
  • Secure fit, maximum comfort and performance
  • Typhoon™ valve reduces breathing resistance
  • Adjustable straps for improved fit
  • Foam strip around the inside forms a better seal
  • Compatible with safety glasses and goggles
  • Conforms to EN149:2009
These SpringFit™ fold flat disposable masks offer a high protection FFP3 level. In addition, they incorporate an activated carbon layer to remove nuisance odours.
SpringFit™ masks have a unique endoskeleton structure inside the mask which results in an unrivalled secure fit for a fold-flat type mask. The structure maximises fit, comfort and performance. The addition of a Typhoon™ valve greatly reduces breathing resistance, heat and moisture buildup. The Typhoon™ value allows normal breathing making the mask more comfortable. The straps are adjustable for a comfortable fit. A foam strip around the inside of the mask adds to the comfort and helps form a better seal. The welded nosepiece improves the fit around the top of the mask. The design of the Springfit™ mask offers greater compatibility with safety glasses and goggles.
Conforms to EN149:2009.
Supplied in packs of 10, each individually wrapped.
4.50 2
