From £41.98 £34.98
  • Self-locking, self-clamping for rapid assembly
  • Invisible fitting clamps with a tensile force of 15kg
  • Requires no further clamping
Customers Also Bought
Book your demonstration
Lamello products are renowned for their precision and quality, saving you time and money with outstanding results. Our knowledgeable and friendly team are available to demonstrate the Lamello range in person or via a video call. You can see the tools in use and ask questions before placing your order.
The Tenso is part of the Lamello Zeta connector range; it anchors in the T-slot in the 'P' system groove. This invisible fitting clamps two parts together with a tensile force of 15kg. The retention force of 25kg makes a tight connection that does away with the need for clamps. Use the Tenso with glue or with normal biscuits or other 'P' style connectors.
Tenso connectors allow you to glue up sections of furniture and then proceed immediately with the rest of the project. You do not have to spend time adding clamps, nor are there any clamps obstructing further work.
The Tenso’s high clamping force is a very desirable feature resulting in a firm joint. However, when using several at a time, it requires a considerable amount of force to make the final connection. For this reason Lamello offer clips that can be pre-loaded in order to lower the amount of force required to make the connection without lessening the final clamping power. Pre-loading takes the form of inserting a small triangular clip between the teeth of the Tenso.
Available in packs containing Tenso and pre-load clips, Tenso connectors only or packs of pre-load clips only.
  • Glue up sections then proceed immediately with the rest of the project
  • Pre-loading lowers the force required without lessening the final power
  • P-System slot cut with either Lamello Zeta P2 or with factory CNC machine
    Customer AccountThe outline of a personCustomer BasketA shopping basket with a handleBulk BuysA star with lots of pointsBusiness ServicesA building with a door at the frontCatalogueAxminster Tools CatalogueCategoriesView categoriesClick & CollectA shopping bag with a handleClockA clock face showing the timeThe CommunityAxminster Tools & Machinery Forum LogoCompareCompare productsDeliveryA van delivering parcelsPremium DeliveryA van delivering parcels fastCopyCopy to the clipboardEditEdit itemEmailAn envelopeEventbriteThe logo for the Eventbrite websiteExpandTwo arrows pulling away from each otherFacebookThe logo for FacebookFilterDots in a triangle shape pointing downfinanceA walletInstagramThe logo for InstagramiwocaPayiwocaPay payment logoLinkedInThe logo for LinkedInLocationA location markerMade in BritainMade in Britain logoMenuThree Horizontal lines stacked on top of each otherPartnerBuy from our PartnersPay By FinanceNovuna Finance LogoPayPalPayPal payment service logoPayPal CreditPayPal credit payment service logoPhoneAn old style telephone receiverPinterestThe logo for PinterestPoint RightAn arrow in a circle pointing rightPrinterA printer, printing a piece of paperPrivatePadlockRemoveTwo lines in a x shapeReturnAn arrow in a circle pointing back to the startRewardsAxminster Tools RewardsSettingsView SettingsSortOne arrow pointing up, one arrow pointing downSpinA circle that spins to show that the page is loadingStockA circle which is coloured to show the current stock levelTagA clothing label tagTeachableThe Logo for TeachableTickA tick symbolTrade AccountSaving tag iconDeleteDeleteUnavailableA no entry signVideo PlayA Circle with a video play symbol insideWarrantyA screwdriver and a spanner in an x shapeWhatsAppThe logo for WhatsAppWishlistA heart symbolWood OutlineWood effectYouTubeThe logo for YouTube
    5.00 9
