Makita LS1219L 305mm Mitre Saw With Laser 230V
- Front facing, twin guide rails allows use flush against a wall
- 305mm blade, large capacity on reduced footprint
- Laser line-of-cut adjustable for left or right of blade cutting
- Dust extraction below and behind blade for clean working
- Soft start for smooth start-ups and longer gear life
- Electronic speed control maintains constant speed under load
- Mitres 0°-60° left and right; bevels 0°-48° left and right
- Mitre stops: 0°, 15°, 22.5°, 31.6°, 45° and 60° (L & R)
- Large aluminium table with pull-out supports
Axcaliber Contract TCT Saw Blade Neg Rake - 305mm x 3.2mm x 30mm 72TFrom £47.78 £39.82
Axcaliber CutPro TCT Saw Blade Neg Rake - 305mm x 2.5mm x 30mm 72TSpecial Price £48.94 £40.78 was £113.98 £94.98 Save £65.04 £54.20
The 305mm Makita LS1219L mitre saw features a motor unit mounted on twin, front facing, steel guide bars. This arrangement allows you to position the saw against a wall thereby gaining valuable floor space, especially when working on site. This dual-bevel, sliding compound mitre saw offers large capacity, accuracy and a reduced footprint. Dust extraction comes in the form of a dust bag or a dual point, adaptor hose for connection to a vacuum extractor. Using the hose adaptor and vacuum means extraction takes place from both behind the blade and below the table.
The motor has both soft start and electronic speed control. An electric brake brings the blade to an almost immediate halt on releasing the trigger.
A laser projects a line across the workpiece as a cutting guide. The laser is adjustable to shine on the left or right of the blade whichever is most convenient. The saw cuts mitres from 0° to 60° both left and right, with indexed stops at 0°, 15°, 22.5°, 31.6°, 45° and 60° (left or right). The bevel capacity is from 0° to 48° both left and right. The LS1219L’s large aluminium base features additional pull-out supports when cutting long timbers.
Supplied with TCT saw blade, dust bag, extraction connector, vertical hold-down and maintenance tools.
The warranty period of your Makita tool may be extended to an additional 2 years subject to the following conditions:
- Makita Tools that are CE marked and (with the exceptions of Batteries, Battery Chargers, Accessories, Petrol Products, Production Tools and Air Tools and Compressors) purchased on or after 1st July 2012.
- The tool is registered by the end user within 30 days of purchase.
For more information and to register your product visit the Makita website.
N.B. Batteries and chargers 1 year warranty. For machines purchased in the UK but then exported, the standard 2 year warranty would apply.
Bevel Angle Range | 48° - 0 - 48° |
Blade Diameter | 305 mm |
Blade RPM | 3,200 rpm |
Bore Size | 30 mm |
Corded or Cordless | Corded |
Dust Collection | Dust Bag Supplied |
EAN Barcode | 0088381854634 |
Electric Brake | Standard Feature |
Laser Class | 2M |
Laser Diode | 650 nm |
Max Bevel Cut @ 45º W x H | 382 mm x 61 mm or 363 mm x 71 mm |
Max Compound Cut @ 45º W x H | 268 mm x 61 mm or 255 mm x 71 mm |
Max Crosscut @ 0º W x H | 382 mm x 92 mm or 363 mm x 107 mm |
Max Mitre Cut @ 45º W x H | 268 mm x 92 mm or 255 mm x 107 mm |
Mitre Angle Range | 60° - 0 - 60° |
Model | LS1219L |
Motor Power | 1,800 W - (230 V) |
Nett Weight | 29.5 kg |
Overall L x W x H | 898 mm x 664 mm x 725 mm |
Rating | Trade/Professional |
Sound Power Level LwA [Uncertainty K] | 100 dB(A) [3.0 dB] |
Sound Pressure Level LpA [Uncertainty K] | 91 dB(A) [3.0 dB] |
Spindle Lock | Standard Feature |
Vibration Cutting Wood [Uncertainty K] | 2.5 m/s² [1.5 m/s²] |
