Axcaliber Pack of 5 Bandsaw Blades - 2,552mm(100.1/2")
719580
From £71.98 £59.98
In Stock
  • Pack of 5 x 2,552mm bandsaw blades
  • Pack comprises 1 each of:
  • 1/4" x 6 tpi Ground Tooth
  • 3/8" x 6 tpi Ground Tooth
  • 1/2" x 3 tpi Ground Tooth
  • 1/2" x 6 tpi Ground Tooth
  • 5/8" x 4 tpi Ground Tooth Freshcut Blade
Axcaliber bandsaw blades are manufactured at Axminster using advanced CNC machining, high precision digital measuring equipment and specialised heat treatment facilities. Detailed quality checks are performed at each stage of manufacture using the most modern inspection equipment. The result is a blade which consistently cuts straighter, has harder, longer-life teeth and which gives a superior finish to the work. The final step in the manufacturing process is one of the most important - the weld. We have invested heavily in this area through the purchase of precision welding and grinding equipment and are, as a result, one of the few companies worldwide able to offer a fully guaranteed weld. Blades are cut accurately to length then, using an IDEAL bandsaw blade welder, a high voltage current is passed through the blade to achieve a precision butt weld. The weld is annealed to remove any brittleness and danger of fatigue and then hand dressed to produce a perfectly smooth joint.
Ground Tooth blades have diamond ground super sharp teeth and work extremely well in all wood giving a high feed rate with exceptionally high quality finish and clean cut and long life.
Freshcut 37 GT Straight Cut bandsaw has precisely ground diamond super sharp teeth with a light set which gives a narrow kerf and reduces the waste produced whilst the hook configuration provides maximum penetration. Perfect for ripping all types of timber, producing veneers and boards.
Made in Britain Made in Britain
4.80 56
