Hermes RB 377 YX Abrasive Belts 100 x 915mm
- Polyester/cotton cloth backed aluminium oxide abrasive
- High stock removal rates in the coarse grit range
- Consistent surface quality in the fine grit range
To fit Axminster AS406/AS408/BD46, Perform CCBD46 and most other 4 x 6" belt/disc sanders. The polyester/cotton back combined with the resin bonded aluminium oxide grain mix produces a high stock removal with coarse grits, plus a consistent surface quality with fine grits. Smooth running and long lasting, perfect for abrading metals and sanding seasoned woods.
Abrasive Backing | Cloth |
Abrasive Belt Length | 915 mm |
Abrasive Belt Width | 100 mm |
Abrasive Type | RB 377 YX |
