Hermes Zirconium Flap Discs
- Layered zirconium abrasive cloth
- 115mm diameter, 22mm bore
- Angled on supporting plate
- Lasts up to 10 times longer than conventional fibre discs
- Particularly effective for rust removal and general finishing
Layers of zirconium abrasive cloth, angled on a supporting plate and lasting up to 10 times longer than conventional fibre discs. As the material wears away it exposes a new, fresh face of abrasive therefore achieving much higher material removal. For use on wood, metal, painted surfaces and masonry. These are particularly effective for rust removal and general finishing. 115mm diameter, 22mm bore.
Bore Size | 22 mm |
Disc Diameter | 115 mm |
