i2R A.22 610 x 610mm 3HP CNC Router 230V
110667
110667
From £4,659.60 £3,883.00
  1. Empty Star
  2. Empty Star
  3. Empty Star
  4. Empty Star
Write a review
In Stock - Ready to dispatch
  • Enquire - contact us for a personalised quote
  • Precision ball screws on each axis
  • Prismatic linear guide rails
  • 2.2kw liquid cooled spindle
  • 610 mm x 610 mm aluminium tabletop
  • Integrated MDF spoil board
  • 4th axis ready
  • UCCNC software
The A.22 CNC Router from i2R is a small but classic machine, favoured within the industry.
Why choose CNC?
An i2R CNC Router will seriously enhance your output in both quantity and quality. By enabling continuous production, you’ll see increased productivity, whilst bringing complex designs to life with precision. This makes the A.22 an indispensable piece of kit, ideal for professional woodworking, small businesses, educational settings, and elite enthusiasts.
The i2R is well-suited for various industries and projects: create custom furniture and intricate carving; rapidly produce prototypes for design projects; create eye-catching signs and lettering; manufacture precise parts for industry applications.
What are you getting?
The A.22 is driven by high precision 16mm ball screws on each axis. There are no pulleys, drive belts or gearboxes, which would add vibration and reduce precision. This is combined with prismatic linear guide rails, which have very low friction in the direction of travel; this increases the accuracy of movement and contributes to the high precision of the machine. Powerful stepper motors run all three axes, for smooth and accurate machining. A 2.2kw liquid cooled spindle (instead of air cooled) increases the lifespan of your machine and improves performance.
An aluminium tabletop with integrated MDF spoil board sits on top of a steel frame. The A.22 has a 610 mm x 610 mm tabletop, which is ideal for a workshop with limited space but is still able to achieve a variety of impressive projects. T-slots in the tabletop and spoil board allow for easy clamping, and the spoil board gives you peace of mind by protecting your aluminium top from any mis-cuts. The machine’s steel base is rigid and sturdy and fits perfectly onto the optional i2R Stand. Cable management is built into the design, so all cables are organised and protected on XY and Z axes.
The i2R CNC router series maximizes UCCNC software capabilities, offering real-time 3D feedback during cuts. You can control every aspect of your CNC machine directly from your computer. The A.22 is configured for conductive tool touch off sensing and is 4th axis ready.
You can tailor your A.22 CNC to meet the needs of your business, your projects, and your space. Our specialist consultants are on hand to build you the perfect package. Optional accessories and upgrades include:
• i2R Stand & Laptop Stand
• i2R Tool Box
• i2R 4th Axis Rotary Kit
• i2R 6W Laser Upgrade
Please note: a laptop is not included. You will need a laptop with an ethernet cable in order to connect to the CNC router. Our specialist consultants can advise you on specification.
Warranty 2 Year Warranty
