Z-Saw Blades for Japanese 265 Kataba Saw - 265mm
- Impulse hardened, diamond ground teeth for long-lasting performance
- Fast cut in larger section timber
- 0.6mm thick and 265mm long blade
- For cutting solid wood, plywood, laminate, man-made sheet, plastics etc.
Changing the blade couldn't be easier; gently tap the back of blade on a block of wood until it comes loose. Remove the old blade, insert the new one into the holder and tap the back of the holder on the block to seat the blade. These blades are 0.6mm thick and 265mm long. Choose between the standard replacement crosscut blade or the universal blade which both crosscuts and performs better on angled or mitre cuts.
Blade Thickness | 0.60 mm |
Kerf | 0.92 mm |
Length of Blade | 265 mm |
