Arbortech Power Carving Unit | Woodcarving Tools
The ideal power source for all your Arbortech attachments! Simply secure any Arbortech attachment to the Power Carver Unit and experience optimal power carving performance!
Experience power carving like never before!
The new variable speed motor is ideal for caving, planing and sanding and comes supplied with innovative accessories, to ensure you get the most out of all your Arbortech attachments.
Getting the most out of your Power Carving Unit
Do you want to... | Combine |
Create extremely flat, levelled surfaces with minimal wood chip? | Power Unit + Levelling Guide + TURBO Plane (not included) + Chip Tube |
Free form sculpt your piece of timber with minimal wood chips? | Power Unit + Chip Catcher + TURBO Plane (not included) + Chip Tube |
Finish off and sand your project with minimal dust and chips? | Power Unit + Chip Catcher + Connected to a vacuum + Sanding Pad fitted with your choice of Sanding Discs |
Use the Industrial Woodcarver Blade or a non Arbortech grinding disc? | Power Unit + Metal Guard + Industrial Woodcarver Blade or a standard grinding disc (not included) |
Or how about sanding off the high points of a wooden surface with minimal wood dust? | Power Unit + Levelling Guide + Sanding Pad + Chip Tube |
What's in the kit?
Power Unit
Robust, variable speed motor that will suit all Arbortech attachments for optimal power carving performance. Use with a combination of included accessories specifically designed for the TURBO Plane (not included) for added features such as dust removal and unique planing and smoothing functionality.
Sanding Pad
Designed for initial sanding stages, this high performance, slightly flexible Sanding Pad is ideal for sanding medium to large projects and is capable of moulding to slight contours due to the flexible lip. Use the Sanding Pad in combination with the Chip Catcher and attach a vacuum to control wood dust.
Levelling Guide
When used with the TURBO Plane, this attachment allows for an extremely flat levelled surface. Use with the Sanding Pad to achieve a very even smooth finish.
Top tip: Connect the Chip Tube to the Levelling Guide to funnel wood chips.
Chip Catcher
Designed to collect dust and chips during free form carving and sanding stages.
Sanding stage:Â fit the Sanding Pad into the Chip Catcher and attach to a vacuum to extract wood dust during sanding.
Carving stage:Â fit the Chip Tube or a vacuum to reduce wood chips during free form carving stages with the TURBO Plane.
Chip Tube
Without a vacuum, the Chip Tube is an easy option to funnel wood chips into a bucket to reduce mess.
Top tip: Once connected to the Chip Catcher or Levelling Guide, the Chip Tube will funnel wood chips straight onto the floor or into a bucket.
Fan
Use the fan in conjunction with the Chip Tube and the TURBO Plane to get rid of most of the wood chips and dust without a vacuum. As well as the above, the package also includes Assorted Sanding Discs (3 x 60, 120, 180, 240 grit) and a metal guard.
Power Carving Project Inspiration
The Arbortech family...
Fast, safe and easy ways to shape wood - get ready to take on a variety of power carving projects with the Arbortech attachments!
Mini TURBO
Carve convex and concave shapes freehand and enjoy a smooth finish that requires minimal sanding.
Create smooth concave shapes and add chiselled features to your projects.
Contour Sander
Achieve exceptionally smooth sanded surfaces.
TURBO Plane Blade
Rapidly shape, sculpt and plane a variety of flat and curved parts.
Shape, sculpt, cut and trench a wide variety of wooden objects.
TURBO Shaft
Perfect for detailed freehand sculpting, this attachment enables unprecedented opportunities for shaping and fine reworking.
Want to see more?
We hope you've enjoyed learning about Arbortech's latest addition! If you want to discover more from Arbortech, why not take a look at another innovative tool that'll revolutionise your woodcarving. Or if it's some project inspiration you're looking for then we have a sound idea, learn how to power carve your own speaker!
Get in touch!
If you’ve bought the Arbortech Power Carving Unit, we’d love to hear from you. Comment below or send us a photograph and tell us all about your new purchase. What do you love about the Arbortech power carver, and why?
Alternatively, get in touch via our social media platforms. Find us on Facebook, send us a tweet or tag us on Instagram using
#arbortechpowercarving to @AxminsterTools.
