Decking Screws from WoodSpur
Regardless of whether you want to build a deck or simply rebuild it, there’s one thing you cannot do without (other than timber), and that’s quality decking screws. When you compare the cost of building a deck with the cost of decking screws, they really do present a small part of the total build budget. One thing is for certain, if you invest in first class decking screws you’ll see a much better return on investment rather cheaper alternatives.
WoodSpur Decking Screws
What is a decking screw?
Decking screws are screws designed specifically for decking. A wooden deck is an outdoor structure that has to bear shifting loads, day after day, so it is important to use screws that will stand the test of time. What this means is that your deck needs to be able to hold itself together.
To achieve an attractive, solid and sturdy deck that you can enjoy safely, it’s always best to opt for purpose-built decking screws such as WoodSpur decking screws. Made from A2 stainless steel, WoodSpur decking screws are highly corrosion-resistant and non-rusting. What’s more, the double thread design pulls boards tight and locks them in place. This makes them ideal for decking use.
Advantages of decking screws
- For quick and reliable assembly, WoodSpur deck screws feature a Torx T25 drive. With this type of drive there’s minimal risk of cam-out and greater transmission of torque. This makes them excellent for pressure treated, tanalised timber.
- What's more, the sharp, penetrating tip eliminates the need for pilot holes, saving you time and effort!
- WoodSpur decking screws are corrosion resistant to prevent rusting and weakness of the structure over the years.
- Deck screws are far superior to nails as the are more secure. They also allow boards to be easily lifted to gain access below the deck for maintenance or repair.
WoodSpur A2 Stainless Steel Decking Screws (Tub 250)From £39.98 £33.32 From £33.98
Discover more…
Enjoyed reading this article? Pop into any of our Axminster stores to see the whole WoodSpur range. We also have several other woodworking projects for you to explore. Try something new with our selection of indoor and outdoor projects. Why not get creative and learn how to make a birdhouse or get top tips on laying a wooden deck?
Get involved!
Have you completed building your own deck at home? Or maybe you lay decking for a job? If so, we’d love to hear from you. Get in touch and tell us your thoughts about our WoodSpur decking screws. Better still, show us your creations! Either comment below, or get in touch via one of our social media platforms. Find us on Facebook, send us a tweet or connect with us on Instagram using #woodspur to @AxminsterTools.
