Festool Dust Extractor | Festool CT-VA Pre-Separator
The Festool CT-VA pre-separator with cyclone technology separates and collects both coarse and fine dust before it reaches your Festool dust extractor. Read our informative guide and learn more about this innovative technology. In doing so, you’ll soon discover for yourself how this is by far the most efficient way of handling large dust volumes.
If you work with materials that produce a lot of dust, the new Festool CT-VA pre-separator could be just what you need. It delivers continuously high-performance dust extraction and is easy to use. It is also simple to dispose of large volumes of dust thanks to the effective pre-separation. Simply couple the pre-separator to your Festool dust extractor using the T-LOC and connect with the hose provided. Finally, thanks to its compact dimensions, modular design and stackable collection containers, it is easy to transport, wherever you are.
Festool cyclone technology
High volumes of dust, shavings and chips are now no longer a problem, neither for the main filter or the suction power. This reduces the load on the main filter and ensures consistently high suction power throughout the work process. The dust-heavy air that's drawn in is swirled into a spiral movement in the cyclone. This causes the dust particles to hit against the wall of the cyclone and, due to gravitational force, to then fall into the collection container of the CT-VA pre-separator.
Features and benefits
- Efficient operation with consistent suction power; dust and coarse particles are separated and collected in the collection container. It collects up to 80% of mineral dust and 95% of coarse particle dust such as sawdust.
- The CT-VA pre-separator is compatible with Festool CT 26/36/48 mobile dust extractors, both with and without AC dedusting. For easy retrofitting, the pre-separator is approved for dust classes L and M.
- Festool's new pre-separator is ideal for demanding everyday use on construction sites. It effectively handles high levels of dust thanks to cyclone technology and ensures constantly high suction power. In addition, the sturdy, high quality components ensure a long service life.
- The sophisticated collection container makes it simple to see how full it is thanks to its transparency. What's more, it's easy to dispose of the contents of the container due to the ergonomic grips on the collection container. This makes the process hassle free and clean.
- Furthermore, the modular design means it is easy to clean the individual parts.
- For flexible working, there's an additional socket for plug in suction hoses and power tools.
- Connect your mobile Festool dust extractor and the CT-VA pre-separator easily using the T-LOC system.
- For complete convenience, it is possible to work either with or without the pre-separator, depending on the application.
- It's straightforward and safe to transport thanks to the sturdy design of the stackable collection container with its compact dimensions.
Applications
Fine mineral dust
There are several benefits of working with the CT-VA pre-separator, especially when working with dangerous, fine mineral dusts. These include:
- Extracts up to 80% of fine dusts
- Quick and easy disposal of dust
- Constant, high suction power
- Work without interruptions, wherever you are working
- Removal of load from the main filter
- Ideal in combination with the Festool CTL/CTM 26/36/48 mobile dust extractors with Autoclean function
- Typical use with Festool tools including long-reach sanders; PLANEX and PLANEX Easy and the RENOFIX RG 130 Diamond Grinder. (Please note: the suction assistance of the PLANEX Classic is reduced when using the CT-VA pre-separator)
Coarse dust
If you work with chips from sawing, routing and planing, the pre-separator offers similar benefits including:
- Up to 95% of dust extracted
- Quick and simple disposal
- Removal of load from filter bag
- Typical use with Festool tools including OF 2200 Router, HK 85 Circular Saw, HL 850 Planer, EHL 65 Planer and ISC 240 Insulating-material saws.
Round Up
The new Festool CT-VA pre-separator is efficient, easy to use and reliable. This makes it the ideal combination when used in conjunction with your mobile dust extractor and tools. Designed for every application, the Festool pre-separator provides optimum results when used in environments with high levels of dust such as on the construction site.
Discover more…
If you love Festool, we've got plenty of new products for you to feast your eyes upon. Firstly, if you want to produce precise, pristine and steady cuts the Festool ISC240Li 5.2 EBI SET FS Insulation Saw 18V (5.2Ah) is just the ticket. Lightweight and ergonomic, the saw cuts insulation material efficiently with minimal effort.
Secondly, the Festool DOMINO DF 500 connector set allows you to produce highly accurate cabinets and joinery items simply and quickly. The new basic structure and furniture connectors are extremely versatile and provide for a very large range of applications. Ideal for use in the workshop, at home or onsite.
Furthermore, Festool fans missed the MFT Fixing Set so much, they just had to bring it back. An ideal supplement to MFT 3 and MW 1000 Mobile Workshop, the new and improved SYS-MFT-FX Set consists of various stops, clamps and clamping elements, all designed to make your life easier. Read our helpful guide and learn why this set is perfect for quick and flexible clamping and securing of workpieces with a wide variety of thicknesses and shapes.
Finally, there's the Festool MW 1000 Set designed specifically for mobile working. Taking the best elements from two existing systems and combining them together, this brand new all-in-one solution provides everything you need for mobile working, wherever you are.
Get in touch!
If you’ve bought the Festool CT-VA pre-separator, we’d love to hear from you. Comment below or send us a photograph and tell us all about your new purchase. What do you love about it, and why?
Alternatively, get in touch via our social media platforms. Find us on Facebook or send us a tweet using #festooldustextractor to @AxminsterTools.
