JSP Force™ 8 and 10 PressToCheck™ Filters - Pairs
- For JSP Force™ 8 and 10
- Instant check that face mask fits correctly
- Ensures intended level of protection
- PressToCheck™ filters available in packs of two
- EN143 P3 High Efficiency Dust Filter
- EN 14387 A2 P3 Medium Capacity Gas/Vapour, High Efficiency Dust
- EN14387 ABEK1 P3 Low Capacity Gas/Vapour, High Efficiency Dust
How can you be sure that your face mask fits correctly and you are gaining the full level of protection as intended? This is something of the utmost importance, particularly where gasses are concerned. With the new patent pending Force™ 8 and 10 PressToCheck™ filters it only takes a couple of seconds to check that you have the correct seal every time. Put your mask on and pull the straps to a suitably tight and comfortable fit. PressToCheck™ - by pressing the fronts and backs of both filters, air is prevented from entering through the filters. When you inhale, no air should come through the mask, if it does then re-adjust the mask and repeat. Using PressToCheck™, you can be sure you are getting the right level of protection. PressToCheck™ filters are available in packs of two. Choose from:
P3 High Efficiency Dust Filter- designed for use on very fine dusts, mists, water based paint, rubbing down paint with a power tool, glyphosate (weed killer), fibres and fibre glass, plaster, silica (concrete/ stone cutting), hard and soft woods, welding (ferrous and lead). EN143 P3
A2 P3 Medium Capacity Gas/Vapour, High Efficiency Dust- designed for use on organic vapours, nuisance odours, fine dusts, mists, water based and solvent based paint, rubbing down paint, paint stripping (chemical or heat), white spirit, glyphosate (weed killer), fibres and fibre glass, hard and soft wood dust. EN 14387 A2 P3
ABEK1 P3 Combination Low Capacity Gas/Vapour, High Efficiency Dust, designed for use on organic vapours, inorganic vapours, acidic vapours, ammonia vapours, nuisance odours, fine dusts, mists, water and solvent based paint, rubbing down paint, paint stripping (chemical or heat), white spirit, chlorine (cleaning and pools), glyphosate (weed killer), brick acid (graffiti removal), formaldehyde, fibres and fibre glass, hard and soft wood dust, MDF (machine tooling), earth moving (contaminated). EN14387 ABEK1 P3
*Please note the information is for guidance purposes only. A proper risk assessment by qualified personnel should be carried out before selecting an appropriate filter cartridge.
