Mafell Erika 85EC Pull-Push Saw System - 230V
108165
From £3,429.98 £2,858.32
  1. Empty Star
  2. Empty Star
  3. Empty Star
  4. Empty Star
Write a review
Available to Order
Delivery
Free Standard Delivery*.
Delivered direct from the manufacturer. Delivery time is approximately 7 days.
  • Everything you expect from a modern pull-push saw
  • High specifications, big capacities and superb performance
  • Integral folding stand for easy transportation
Mafell's Erika 85EC, there’s a clue in the name; it has a maximum depth of cut of 85mm. This impressive cutting height is backed up by plenty of power. Mafell produced the world's first pull-push saw almost 40 years ago. The Erika 85EC, from the current generation offers everything you expect in a modern pull-push saw. This is a superb piece of kit and the pull-push saw action offers great potential.
When cross cutting, the work remains stationary supported against the MFA fence. The blade is pulled forwards and through the work. In many ways it takes over many functions of a crosscut mitre saw. The Erika 85EC gives you a maximum pull cross cut of 430mm. The MFA multipurpose guide fence has two faces at 90°, perfect mitres are guaranteed every time. Ripping is carried out with the MFA fence on the right hand side with the blade locked. The blade tilts for bevel cuts from -3° to +48°.
The riving knife can be removed for plunge cuts, made by raising the blade up through the work.
The 2,500W CUprex motor runs ultra smooth and features variable speed. The Erika 85EC is suitable (with the correct blade fitted) for cutting solid wood, manmade boards, plastics and aluminium profiles. The integral folding stand makes for easy transportation and quick set up on site. The rear legs have wheels for maneuverability. An adjustable leg ensures stability on uneven surfaces.
Extraction is from above and below the blade. When hooked up to a vacuum, extraction is highly efficient. All the controls are situated on the front of the machine, including the NVR on/off switch.
This is a precise cutting machine; adaptable, flexible and configurable to the task at hand.
Supplied with a 250mm 40T TCT blade, MFA multi-purpose fence, extraction set and push stick.
Optional parallel fence with adjuster available please contact our sales teams for more details.
Warranty Mafell 3 Year Warranty (Registration Required)
Register on the Mafell website and select NMA Agencies, Brighouse from Dealer options.
In case of a warranty claim please contact NMA Agencies NMA Customer Service Team on - Tel: 01484 400488
For warranty issues outside of the UK, tools must be returned to the UK at the customer's own cost.
Register now
