From £209.98 £174.98
Low Stock
- get it Tuesday 28th Mar, order within and choose Premium delivery. Delivery info
  • One motor with 3 different bases: plunge, trimming and bevel
  • Host of small routing and trimming tasks in the workshop or on site
  • Motor is fitted with variable speed control, soft start
Customers Also Bought
Total:
£354.22 £295.18
Compact router trimmer that combines one motor with different bases. This machine is great for a host of small routing and trimming tasks in the workshop or on site. The motor is fitted with variable speed control and has a soft start. It can be quickly interchanged and locked into the required base. This kit comes complete with three bases; Plunge, Trimming and Bevel.
Plunge base: turns the machine into a plunge router with 2 solid grip handles, a height adjuster with fine adjustment and a stepped turret for repetitive depth setting. The side fence fits left or right. Easy to control, suitable for decorative edge working as well as small mortices and grooves.
Trimming base: this small 90mm round base turns the machine into a trimmer for single handed use. Use with or without the height adjustable bearing guide for cutters without bearings, rolling on the curve for a fine cut. A trimmer guide is supplied for curved work or the side fence can be used for straight work.
Bevel base: a small square 90mm base that can tilt and be locked at a required angle (45°-0°-30°), allows for more scope when profiling and jointing.
In addition the machine is supplied with a 1/4" collet (The RT0702 will accept a 3/8" collet not supplied), Side fence, Trimmer guide, 16mm & 10mm template guides, side grip handle (can replace right plunge base handle), dust extraction set, 13 and 22mm wrenches and tool bag.
Note: This router is fitted with an Anti Restart Safety Switch and is incompatible with a seperate external NVR switch.
  • Can be quickly locked into the required base
  • Plunge base: 2 solid grip handles, quick and fine height adjuster
  • Trimming base for single handed use, fitted with bearing guide
  • Bevel base can tilt and be locked at a required angle
  • Trimming guide with roller bearing for curved edge work
  • The machine is also supplied with a 1/4"collet, side fence, 16mm & 10mm template guides, side grip, dust extraction shrouds, 13 and 22mm wrenches and tool bag.
    Customer AccountThe outline of a personCustomer BasketA shopping basket with a handleBulk BuysA star with lots of pointsBusiness ServicesA building with a door at the frontCatalogueAxminster Tools CatalogueCategoriesView categoriesClick & CollectA shopping bag with a handleClockA clock face showing the timeThe CommunityAxminster Tools & Machinery Forum LogoCompareCompare productsDeliveryA van delivering parcelsPremium DeliveryA van delivering parcels fastEditEdit itemEmailAn envelopeEventbriteThe logo for the Eventbrite websiteExpandTwo arrows pulling away from each otherFacebookThe logo for FacebookFilterDots in a triangle shape pointing downfinanceA walletInstagramThe logo for InstagramLinkedInThe logo for LinkedInLocationA location markerMade in BritainMade in Britain logoMenuThree Horizontal lines stacked on top of each otherPartnerBuy from our PartnersPay By FinanceNovuna Finance LogoPayPalPayPal payment service logoPayPal CreditPayPal credit payment service logoPhoneAn old style telephone receiverPinterestThe logo for PinterestPoint RightAn arrow in a circle pointing rightPrinterA printer, printing a piece of paperPrivatePadlockRemoveTwo lines in a x shapeReturnAn arrow in a circle pointing back to the startSettingsView SettingsSortOne arrow pointing up, one arrow pointing downSpinA circle that spins to show that the page is loadingStockA circle which is coloured to show the current stock levelTagA clothing label tagTickA tick symbolTrade AccountSaving tag iconDeleteDeleteTwitterThe logo for TwitterUnavailableA no entry signVideo PlayA Circle with a video play symbol insideWarrantyA screwdriver and a spanner in an x shapeWishlistA heart symbolWood OutlineWood effectYouTubeThe logo for YouTube
    5.00 1
