Narex Carving Mallets
- Selected Beech wood with well shaped handles
- Small: 63mm diam x 87mm Overall 250mm Weight: 250g
- Large: 98mm diam x 137mm Overall 300mm Weight: 600g
FlexiSander Dual-Grit Sanding Pads - 90 x 19 x 6mm (Pkt 3)Special Price £2.95 £2.46 was £3.68 £3.07 Save £0.73 £0.61
Turned from selected Beech wood, these carver’s mallet feature well shaped ergonomic handles. The handles have a bulbous end to prevent the mallet slipping out of your hand when in use. Beech wood is known for its density and resilience, which is why it is often the timber chosen for the tops of professional woodworking benches. Available in two sizes, both of which will give years of good service.
Smaller: Head: 63mm diameter x 87mm long. Overall: 250mm. Weight: 250g.
Larger: Head: 98mm diameter x 137mm long. Overall: 300mm. Weight: 600g.
Quality tools made in Europe.
