Perform PD1400B Bandsaw 230V
- Ideal beginner bandsaw
- Compact, yet sturdy and versatile
- 80mm depth of cut, 195mm width of cut
Axminster Magnetic Hose Coupler - 63mmSpecial Price £15.38 £12.82 was £21.98 £18.32 Save £6.60 £5.50 -
Axminster Magnetic Female Coupler - 63mmSpecial Price £4.38 £3.65 was £6.28 £5.23 Save £1.90 £1.58
The Perform PD1400B Bandsaw is ideal for beginners or small home workshops.
It features a strong chassis with a cast aluminium table, providing a solid, sturdy working area. The machine accommodates blades between 4.8 mm and 9.5 mm wide and offers a maximum cutting height of 80 mm, delivering excellent versatility for a variety of cutting tasks.
Driven by a reliable, quiet induction 250W motor, the PD1400B delivers a blade speed of 960 m/min. It has balanced cast alloy wheels. The top wheel is mounted in a welded steel sub frame with blade tensioning and tracking controls conveniently close. The quick tension release ensures for simple and rapid blade changes.
Bearing blade guides and a thrust bearing provide maximum blade control, ensuring improved accuracy and clean cuts.
The 300 x 300 mm table tilts to 45° , whilst the rack and pinion allows for smooth table adjustment so you can cut at different angles with ease. A mitre fence is included, allowing you to produce accurate crosscuts whilst the rip fence ensure for straight and accurate cuts.
The micro-switched doors ensure the machine automatically stops running if a door is accidentally opened, providing an extra layer of safety during use.
The 28mm dust extraction outlet allows efficient dust collection when connected to a suitable vacuum extractor, helping to maintain a clean and safe workspace.
This compact, yet versatile machine makes an excellent beginner bandsaw. It's great for cutting wood, aluminium and plastic.
Perform 1 Year Guarantee
With every Perform machine, you get our 1-year guarantee, which includes:
Complete machinery coverage (excluding blades, abrasives, belts, filters/bags, other consumables).
Machine Classifcation
These products are designed for light, occasional use. They must be maintained and serviced in line with our schedule and are not intended for continuous or high operation, otherwise guarantee may be void.
Find out more| Bandsaw Blade Length | 1,400 mm (55") |
| Bandsaw Wheel Diameter | 200 mm |
| Blade Width Min\Max | 4.8 mm to 9.5 mm |
| Dust Extraction Outlet | 63 mm |
| EAN Barcode | 5052511142194 |
| Max Cutting Height | 80 mm |
| Max Width of Cut | 195 mm |
| Max Width of Cut with Fence | 130 mm |
| Min Extraction Airflow Required | 200 m³/hr |
| Model | PD1400B |
| Nett Weight | 17 kg |
| Overall L x W x H | 420 x 400 x 690 mm |
| Plug Fitted | UK 3 pin plug |
| Power | 250 W |
| Rating | Occasional Use |
| T Slot Size | 10.5 x 3.5 mm |
| Table Height | 320 mm |
| Table Size | 300 x 300 mm |
| Table Tilt | 0° - 45° |
| Voltage | 230 V |
- Standard Delivery* - Free
Please note, respiratory items cannot be accepted for a refund once the seal is broken and the item has been worn.
