Pony Adjustable Tension Spring Clamps
From ÂŁ3.40 ÂŁ2.83
1 Review
  • Controllable clamping pressure 0 to 22.5kg
  • Lightweight, virtually unbreakable clamps
  • Pivoting jaw pads hold irregular workpieces
Take the pressure off, or turn it up, you’re in control with these Pony spring clamps. By simply turning the adjusting screw using a PH2 screwdriver you can change the clamping pressure anywhere between zero and 22.5kg. This makes these clamps ideal for a very wide range of applications, from very delicate projects and upwards. The plastic bodies are tough and virtually unbreakable. Pivoting jaws automatically adjust when holding irregular‑shaped workpieces.
5.00 1
