Pony Adjustable Tension Spring Clamps
- Controllable clamping pressure 0 to 22.5kg
- Lightweight, virtually unbreakable clamps
- Pivoting jaw pads hold irregular workpieces
Axminster Professional Forged Flat Bar Clamp 200 x 80mmSpecial Price ÂŁ10.44 ÂŁ8.70 was ÂŁ15.58 ÂŁ12.98 Save ÂŁ5.14 ÂŁ4.28
Axminster Professional Stainless Steel Metric Rule - 300mmSpecial Price ÂŁ2.68 ÂŁ2.23 was ÂŁ3.58 ÂŁ2.98 Save ÂŁ0.90 ÂŁ0.75
WoodSpur Torx Head Wood Screw Assortment (1,500 Pieces)Special Price ÂŁ24.98 ÂŁ20.82 was ÂŁ29.98 ÂŁ24.98 Save ÂŁ5.00 ÂŁ4.17
Axcaliber 12 Piece 1/4" (6.35mm) Long Shank Cutter SetSpecial Price ÂŁ69.97 ÂŁ58.31 was ÂŁ89.98 ÂŁ74.98 Save ÂŁ20.01 ÂŁ16.67
Take the pressure off, or turn it up, you’re in control with these Pony spring clamps. By simply turning the adjusting screw using a PH2 screwdriver you can change the clamping pressure anywhere between zero and 22.5kg. This makes these clamps ideal for a very wide range of applications, from very delicate projects and upwards. The plastic bodies are tough and virtually unbreakable. Pivoting jaws automatically adjust when holding irregular‑shaped workpieces.
