These Easy Wood Easy Reach Dovetail Jaws are perfect for providing a strong and reliable grip on your workpiece. They are particularly suited to smaller projects like pen blanks and small spindle work as they can grip onto longer pieces of work with ease.
Swapping your jaws is easy; use the ball and hex key, press down on the keeper latch, slide your jaws on, listen to the snap and the jaw is then locked into position within 30 seconds.
Available in 3 sizes; 1/2, 1.3/8, 3.1/2. Compatible only with the Easy Chuck.
The 1/2 Easy Reach Dovetail Jaws grip tenons at 1/2+ and expand into mortices at 1.1/4+. The jaw length is 1.1/4. These jaws are perfect for pen turning and other small projects due to its inside flat surface.
The 1.3/8 Easy Reach Dovetail Jaws grip tenons at 1.3/8+ and expand in mortices at 2+. The jaw length is 1-1/4.
The 3.1/2 Easy Reach Dovetail Jaws grip tenons at 3.1/2+ and expand into mortices at 4.1/4+. The jaw length is 1. These jaws have grooves inside for additional grip and are useful for projects such has pepper mills.
Manufactured with hardened and plated components and machined to high tolerances.
Web Attribute Set Jaws for Four Jaw Chucks
