The Precision Router Table Insert Plate – Undrilled provides a solid, flat and reliable mounting surface for fitting a router into a table. Manufactured from 9mm thick phenolic, it is designed to resist sagging and remain stable over time, even when supporting larger, heavier routers. Measuring 235mm x 298mm, the plate suits a wide range of router tables and applications, making it a practical choice for custom setups or replacement installations.
The undrilled format avoids unnecessary mounting holes, allowing a clean, uncluttered installation tailored to your specific router. Alignment marks engraved on the underside make it easy to centre the router accurately, with clearly marked starting points to assist drilling for many popular models. This approach ensures precise positioning while maintaining maximum strength and rigidity.
Supplied with Level‑Loc reducing rings, the insert plate allows the cutter opening to be adjusted quickly and securely. The rings twist into place and lock flush with the surface, helping maintain accuracy and smooth material support around the cutter. Designed for flexibility, the insert plate is also available in alternative versions pre‑drilled for specific router models, allowing users to choose the option best suited to their setup.
Ssupplied with three Level‑Loc reducing rings, including 25mm, 30mm (for use with universal‑style guide bushings) and 67mm sizes, along with installation instructions to support accurate setup and mounting
