The Kreg True‑FLEX Featherboard is designed to provide consistent, controlled pressure to help improve both cutting accuracy and safety when working at the table saw or router table. Carefully engineered fingers apply an even, optimum pressure to the workpiece, avoiding the common problem of featherboards that press too hard or not enough, which can affect cut quality and control.
Manufactured from a durable plastic composite, the featherboard is built to withstand regular workshop use while maintaining reliable performance. The integrated Wedge‑Lock system allows it to be secured quickly and firmly in either a mitre slot or T‑slot without the need for additional hardware. Designed for standard 9mm x 19mm mitre slots, it adapts easily to a range of machines, giving confidence and repeatability during cutting operations.
Supplied as a twin pack, the True‑FLEX Featherboard offers added flexibility for supporting workpieces in multiple positions, making it a practical addition to both router table and table saw setups.
