Experience exceptional precision and power with the Laguna 14|BX Bandsaw, a premium choice for professional joinery shops and serious home workshops. This bandsaw is designed with a robust build quality and advanced features that ensure superior cutting accuracy and ease of use. The 14|BX offers a balanced combination of outstanding build quality, large cutting capacity and innovative features, making it ideal for a wide range of woodworking tasks.
The 14|BX features a reinforced pyramid shaped spine in a one piece frame construction that incorporates the stand this further minimises frame distortion when the blade is fully tensioned, providing you with the precision you need for every cut. The ceramic blade guide system, a hallmark of Laguna bandsaws, creates 10 points of contact on the blade. Positioned above and below the table, these guides ensure easy setup and highly accurate cuts, even when re-sawing deep timber. The long-life ceramic guides offer a larger blade contact area than traditional bearing guides, resulting in more support for the blade and greater cutting accuracy. With a maximum cutting depth of 330mm and a cutting width of 310mm with fence, (340mm without) this bandsaw is perfect for handling a variety of tasks, allowing you to cut through thick materials with ease and precision.
The 14|BX is equipped with a powerful 1.9kW (2.5hp) braked motor with a foot operated disc brake system that provides ample power to handle a wide range of tasks whist stopping the blade even more quickly in case of an emergency, reducing the risk of accidents. By pressing the foot pedal firstly cuts power to the motor and secondly activates the disc brake to bring the saw to a virtually instantaneous stop.
The double viewing windows allow you to check both tension and tracking while the machine is running. Additionally, the quick-release blade tension lever makes it easy to change blades without compromising safety and means you can easily release the tension stress on the blade when not in use to help prolong blade life. The solid cast wheels are fitted with polyurethane tyres that provide cooler operation and longevity. The worm gear and pinion on the blade guard rise and fall is ultra-smooth and engineered to have minimum flex, even when fully extended. Fitted with twin 100mm dust collection outlets for easy connection to a dust extractor to help keep your workspace clean.
The fully adjustable Hi-Lo aluminium fence enhances versatility, allowing for full and precise timber support for both large and small work pieces. The fence height can be adjusted to 140mm or 12mm, providing flexibility for different cutting needs. Additionally, the table insert adjustment allows for simple levelling, and the table tilts to 45 degrees with a positive Stop at 90°. A flip plate allows reverse tilt up to 7 degrees when required, providing flexibility for a variety of cutting angles. The micro-polished cast iron table, measuring 406mm x 546mm, is mounted onto an oversized double cast iron trunnion with two locking points, ensuring a solid surface to work from. This table size provides ample workspace, making it easier to handle larger pieces of material. In the centre of the table is an anodised aluminium throat plate, with 4 adjusting screws, to ensure a perfect flush fit.
Elevate your woodworking capabilities with the Laguna 14|BX Bandsaw. Its exceptional precision, powerful performance, and versatile features make it the perfect addition to any high-end workshop. Investing in this reliable and innovative machine will allow you to achieve unparalleled accuracy and efficiency in your projects, ensuring that every cut is smooth and precise.
Supplied with Axcaliber Ground Tooth Blade 2,920mm (115) x 1/2 6TPI.
N.B. This Machine requires a 16 amp supply and it's recommended that a C Type breaker is used, if you are unsure please contact a qualified electrician.
Axminster Tools offers an optional 2-year extended warranty on all Laguna machines, ensuring peace of mind and comprehensive coverage. This extended warranty must be purchased at the same time as your Laguna machine. Please see the warranty link below for more details.
Dust Extraction Outlet 2 x 100 mm
Max Width of Cut with Fence 300 mm
Overall L x W x H 755 x 713 x 1,790mm
Power 1.9 kW
T Slot Size 19 mm & 25 mm
Table Height 965 mm
Table Size 406mm x 546mm (16 x 21.5)
Min Extraction Airflow Required 1,000 m³/hr
Plug Fitted UK 16A Plug
Web Attribute Set Bandsaws
EAN Barcode 5052511135318
  • UK Mainland - £70
