Perform
Perform Replaceable Tip Turning Tool Set (3pc)
SKU: 113575
€54,00
  • Replaceable TCT tips stay sharp longer
  • Three cutters for a range of turning tasks
  • No sharpening - just rotate or replace tips
  • Comfortable beech handles for easy grip
  • Ideal for beginners and smaller projects
The Perform Replaceable Tip Turning Tool Set is a an ideal choice for those who are beginner turners, or those seeking durability and convenience. Each tool measures 330mm in overall length, providing a balanced feel that supports both precision and control during turning tasks. Designed with replaceable tungsten carbide tips (TCT), these tools offer extended life and maintain sharpness longer than traditional high-speed steel alternatives.
The set includes three cutter profiles to suit a range of turning applications: an 11mm square cutter for roughing and removing square stock, a 12mm round cutter ideal for curves and contours like the inside of a bowl, and a 10 x 28mm diamond-shaped cutter suited for fine detail work, tight corners and creating beads. The replaceable tip design simplifies maintenance - when the cutting edge dulls, simply rotate or replace the tip and you're good to go again; there is no need to sharpen. Easy to control, these tools sit parallel to the floor on the tool rest. Simply move across the rest to use.
The handles are made of smooth beech for a comfortable fit.
This set is well-suited for turners who are beginning their woodturning journey and makes an ideal accessory for the Perform PD240WL Woodturning Lathe. They are suited to smaller projects.
Web Attribute Set Woodturning Tools - Sets
EAN Barcode 5052511143115
