The SawStop Industrial Cabinet Saw Mobile Base makes moving heavy machinery effortless. Designed to support up to 450 kg, it’s perfect for both industrial workshops and home workspaces, and requires no extensions. Easily move your saw around your workspace for maximum versatility.
Equipped with a hydraulic piston lift, the saw can be raised in just three pumps of the foot pedal. Four 360° full ball-bearing casters provide smooth, multidirectional movement, making it easy to position the saw in a corner or store it when not in use.
When disengaged, the saw rests securely on the floor, placing the weight on the ground rather than the wheels - eliminating any concern about caster damage. The polyurethane wheels are non-marking so will not mark your floors.
