This solid carbide cutter has a 30mm depth of cut and allows you to take more advantage of Origin’s full Z-axis travel range; the increased pass depth makes your Origin projects more efficient, with no compromise on cut quality or stability. Three flutes are ideal for a wide range of materials, from foam to hardwood, and the solid carbide composition stays sharp even after hours of use. Save time when changing bits thanks to the marked shank for accurate collet clamping.
Overall Length: 80mm
Shank Diameter: 8mm
Cutter Diameter: 6mm
Cutter Length: 30mm
Usable Length: 45mm
Geometry: Upcut, Spiral, 3 flute
Material: Solid Carbide
Web Attribute Set Spiral Router Cutters
