Unlock stuck parts fast with Fast Release Penetrant. Formulated to perform in temperatures from ‑20°C to +90°C, it rapidly breaks through rust, corrosion, and grime to free seized components with ease. Safe for use on metal, alloys, rubber, plastic, and most painted surfaces, it’s the ideal solution for restoring movement and keeping mechanisms working smoothly. The nozzle on the can allows for a wide spray, narrow straw spray and can be used up to 360 degrees in rotation.
Available Sizes 400 ml (aerosol)
EAN Barcode 5032227443488
Accessories
  • Roughneck 3 Piece Mini Wire Brush Set
    $8.99 USD
  • WD‑40® Multi-Use with Flexible Straw 400ml WD‑40® Multi-Use with Flexible Straw 400ml
  • WD‑40® Specialist Dry Lubricant 400ml
  • WD‑40® High Performance Lithium Grease White 400ml WD‑40® High Performance Lithium Grease White 400ml
  • WD‑40® High Performance Silicone Lubricant 400ml WD‑40® High Performance Silicone Lubricant 400ml
  • WD‑40® Fast Drying Contact Cleaner 400ml WD‑40® Fast Drying Contact Cleaner 400ml
  • GT 85 Machine Maintenance Spray 400ml GT 85 Machine Maintenance Spray 400ml
  • WD‑40® Multi Use with Smart Straw 500ml
