This 10 piece set of PROXXON MicroSpeeder combination ratchet spanners comes in a practical folding case. MicroSpeeder spanners have compact and very slender heads allowing greater access in tight spots. The ratchet ring features an inner gear ring with 72 teeth meaning it is still effective with only 5° of movement. The thumb operated reverse lever easily switches the ratchet direction. The head has a 15° offset allowing easy use on a flat surface.
These chrome vanadium steel spanners undergo double nickel-plating followed by matt-finished chrome plating for long life. Durable laser marking means permanent easy-to-read sizes. Designed for professional industrial use it comes with a 2 year guarantee. The folding case keeps them organised on site and also has holes for wall mounting in the workshop. The set comprises sizes 8, 10, 11, 12, 13, 14, 16, 17, 18 and 19mm.
Compact and slender heads give better accessibility
Ratchet mechanism with reverse lever on ring end
72-tooth inner gear ring, effective with only 5° of movement
15° offset for greater accessibility
Neat, folding, organised storage case
Durable laser marking for permanent easy-to-read sizes
